2002 idle cable
Old Dec 8, 2011 | 02:15 AM
francisac's Avatar
francisac
Default 2002 idle cable
Hey everyone im new to this form and to Harley, but i thank you for your answer ahead of time. I need and extended idle cable and i see in the J P has one and i would like to know if it come with the roll off switch for cruise as the stock has. Thanks
Old Dec 8, 2011 | 03:10 AM
Stiggy's Avatar
Stiggy
Welcome to the forum!
You don't offer much information, but I think I know what you're asking.
If a part number is spec'd for a bike, ( like an Ultra that has cruise,) then PROBABLY it will include the switch. If that part number also includes bikes that do not come with cruise as standard, then probably not. ( Idle cables for cruise are more expensive than throttle cables, typically.)
Is there a customer service number you can call before ordering?
Being new to HD's, there are a lot of vendors with a lot of choices out there. Go slow and learn first. And ask a lot of questions.
Good Luck!
Old Dec 8, 2011 | 09:03 AM
gtrplyr's Avatar
gtrplyr
I have an 02 RK and recently switched out both my throttle and idle cables for longer ones due to 12" apes. Drag Specialities has OEM style black cables for pretty cheap. You can get the part number off their website and check your preferred dealer to see if they have them in stock. As long as you order a cable for a bike with cruise it will have the cruise sensor in the middle of the line.
Hope that helps.
Old Dec 8, 2011 | 08:42 PM
francisac's Avatar
francisac
thanks i for all the info
72Norton
Jan 1, 2014 03:36 AM
sedouglas
Feb 13, 2012 07:12 PM
bcp07sg
Jun 18, 2011 06:15 AM
Maddogs700srx
Jun 6, 2010 10:55 PM
John TN
Mar 14, 2005 11:34 PM
