Checking Oil
Old Dec 8, 2011 | 11:28 PM
SportyPig's Avatar
SportyPig
Default Checking Oil
Ok...it's time for another stupid question....
Who do ya hafta know to get the oil check dip stick out. Especially when the engine is warm or hot. Is there a "special tool" for this? I know there is a tool for the oil filter. Only way I've been able to get it off is to take a thick towel, wrap it around the cap, and then gently use channel locks.
That doesn't work very well when out on the road. I'd rather not carry all that stuff just to check the oil.
Old Dec 8, 2011 | 11:40 PM
Chunker's Avatar
Chunker
Don't put it back on with channel locks
Old Dec 8, 2011 | 11:46 PM
thenewrage's Avatar
thenewrage
I keep mine snug by hand. I never use tools on it. Ive never had a problem with this method and its never loosened up on me.
Old Dec 9, 2011 | 03:49 AM
Mighty Nation's Avatar
Mighty Nation
You need to take your hand off your tool and start doing finger pushups.
Old Dec 9, 2011 | 04:59 AM
skully1200's Avatar
skully1200
Not sure if your bike is different than my 04, but on mine I grab it with my hand and pull it out. The dipstick, that is.
Old Dec 9, 2011 | 05:11 AM
SportyPig's Avatar
SportyPig
Mine is threaded. And I didn't put it back on with channel locks. Just hand tighten. But, there is NO way I can get my hand around the cap when the bike is warm or hot.
Old Dec 9, 2011 | 05:25 AM
Jinks's Avatar
Jinks
The newer digital dipsticks work pretty well. They give you oil temp. & level at the touch of a button. OTOH, if you're on the road, don't have oil all over the bike & it's been runnin' good you probably don't have an oil problem............
Old Dec 9, 2011 | 05:27 AM
Drew's Avatar
Drew
Special tool: http://www.hdsmartsocket.com/
No affiliation, and I'd never buy one, I just leave my gloves on, and check the oil.
TUCCI's Avatar
TUCCI
Its hot and once your engine is pretty much broke in and the consumption is predictable, I only check my oil about every couple hundred miles.
Old Dec 9, 2011 | 06:34 AM
jmacdonald5's Avatar
jmacdonald5
...first off...why are you checking it when it's so hot?...just check it when it's cold before you take off on a run...if it's in the middle of the safe-range on the stick when it's cold, then it's fine.
