Exhausts for Road King
I have a new FLHRI. I want to replace the exhaust/mufflers so that I get that "Harley" sound. Performance is not important. Has anybody got any ideas or recommendations. I had screaming eagle mufflers on an 883 sportster but I thought that they were too loud and became oppresive on a run. Something that gives me about threequarters of what the screaning eagles gave me would be fine.
Thanks.
Thanks.
RE: Exhausts for Road King
Bubs true dual system is nice, but It all depends on what mufflers you use. I would recommend a system with removable baffles in that you can re-pack or pack them tighter to change the output noise. You might want to try a local bike night and listen to other bikes to give you a better 'real life' opinion.
ORIGINAL: chunkbear
Thanks.
Thanks.
Well, I've got the Hooker slip-ons and they are attached onto true dual Bassani headers. These are a bit loud to say the least, but can be nice rumble at lower rpms. If you want the potato-potato sound this is definetily it. If you do not run true dual, then you'll get an annoying popping sound from the left side. Also, if you put a cam in then it gets very loud if you grab a handfull, but sounds very nice in cruise mode. The other plus is that you don't have to romove them to get the rear tire off like many other slip-on. As far as workmanship, I've found none better. I've got some hard long miles on these and the chrome looks just like the day I bought them. No yellow, purple or otherwise. Hope this helps.
Scorpion
Scorpion
kmayHD
11-28-2011 08:46 AM
