Just took my inner fairing off and painted it. Put everything back together and was checking everything out to make sure it works. When i was checking the trip meter on the speedometer and checking the amount of fuel till empty it says LO? I have a half of tank of fuel so it has plenty of gas. I was wondering is there a connector that I forgot to plug in? Any suggestions would be greatly appreciated.
If I remember correctly I think if you have had the main fuse out for a while you will need to go for a ride and it will update........Until then it will remain on LO
My bud did that same problem. He had the air temp gauge plugged into the fuel I believe he said. I will buzz him up in a while and see.
I have not had that problem my self and I have installed over 30 inner fairing. Never had to reset that switch on any bike yet.
