how to remove rear caliper on 2010 Street Glide
Old 03-01-2012, 06:59 PM
TexasHarleyBoy's Avatar
TexasHarleyBoy
TexasHarleyBoy is offline
Default how to remove rear caliper on 2010 Street Glide
i got my new tires in and was taking the wheels off so i could take them to my indy to have new skins put on, and i have hit a small, i hope, brick wall. i cannot get the caliper to clear the disc on the rear wheel/tire assembly. i have almost taken the axle all the way out, but have left enough of it in to support the wheel. the Book said to take it out prior to removing the axle, tried that but would clear the disc so out came the axle. i don't know what i'm doing wrong. any ideas where i'm messing up. the caliper will almost clear, but then hits the wheel and tire. HELP!!!
Old 03-01-2012, 07:10 PM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,729 Likes on 1,302 Posts
Twist the caliper on the disc with both hands to retract the pistons, it will give enough room to remove the caliper
Old 03-01-2012, 07:48 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
I use plastic paint scrapers, one each side of the disc.
they are enough of a wedge to push the pads/pistons back into the caliper.
is important not to use metal ( like a screwdriver, chisel) as that'll marr the pads
mike
TexasHarleyBoy
That did it!!! Thank you so much for the tip! Thats one of the things I love about Harley's and the guys that ride them, they will help you if they can! Thanx brother
Old 03-01-2012, 08:17 PM
DPete's Avatar
DPete
DPete is offline
Yer welcome, glad you got it.
Alter
06-24-2012 05:36 PM
trainwreak
05-06-2011 08:42 PM
albngore
02-14-2011 08:44 AM
HDV-GLIDE
01-13-2010 05:25 PM
jbt
11-06-2006 06:07 PM
Quick Reply: how to remove rear caliper on 2010 Street Glide
