Rear caliper
Old Jan 13, 2010 | 04:34 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Rear caliper
OK, got the rear axle off and separated the caliper from its axle post..
HOW THE HELL DOES THE CALIPER CLEAR THE WHEEL TO COME OFF OF THE ROTOR????
One hour now attempting to remove it.......I had my V-Rod rear wheel off umteen times without an issue, this thing is driving me crazy...............................
Old Jan 13, 2010 | 04:41 PM
lp's Avatar
lp
You can insert a flat head screw driver between the pads and push the pistons back and that may give you the clearance you need or you can remove the pads from the caliper. Thats the way I've done it.
lp
Old Jan 13, 2010 | 04:49 PM
Jday53's Avatar
Jday53
should beable to wiggle and push the caliper of its mount and move it out the way jack the bike up higher
Old Jan 13, 2010 | 05:23 PM
HDV-GLIDE's Avatar
HDV-GLIDE
What's that saying, if your frustrated walk away and when you return it usually will work out. Well, I walked away, posted the thread, walked back outside and after jacking the rear wheel up some, I was able to wiggle the damn caliper off the rotor.
After wrestling with the 240 tire on the V-Rod, the 180 was a piece of cake to remove from under the fender.
Off to the dealer tomorrow for new wheel bearings and then the fun begins on the install.
Old Jan 13, 2010 | 05:25 PM
strtarrow's Avatar
strtarrow
I get some of my best ideas when I take a shower. Either that or fire up a doob....
800screws
EVO
Dec 24, 2014 02:16 PM
Red Dragons
Jun 10, 2014 03:09 PM
Alter
Jun 24, 2012 05:36 PM
TexasHarleyBoy
Mar 1, 2012 08:17 PM
pelone
May 1, 2009 09:42 PM
