True Duals causing vibration ?
Old Dec 28, 2006 | 10:43 PM
phantomroadking's Avatar
phantomroadking
6th Gear
Default True Duals causing vibration ?
Just put a set of v&h big shot true duals on my 2000 roadking. Got to say they sound great! I took it for a spin and i noticed the floorboards vibrating more than before. Just wondering if anybody noticed the same thing. Thanx.
Old Dec 28, 2006 | 10:51 PM
Abnmarine's Avatar
Abnmarine
Default RE: True Duals causing vibration ?
Check to ensure that none of the heatshields are touching the frame or rear brake lever. I had a simular issue that was traced to this.
Old Dec 28, 2006 | 10:58 PM
Mountainkowboy's Avatar
Mountainkowboy
Sounds like you pipe is hitting your board. I had the same problem with my Santee 2-1/4 true duals, I ended up doing the 3/4" board extensions. Cured the problem and was a more comfortable foot position too.
Old Dec 28, 2006 | 11:12 PM
classic cruiser's Avatar
classic cruiser
Make sure your mufflers are centered on the rear mount. When I put my Rineharts on my other bike I had the same vibration. I recentered the mufflers and it was gone.
Old Dec 28, 2006 | 11:50 PM
kt's Avatar
kt
I had to put a spacer on the right board to move it out a small amount. Cured mine.
Old Dec 29, 2006 | 12:28 AM
Custom07RKC's Avatar
Custom07RKC
Did you install the floorboard spacer that is supposed to come in the kit with the pipes. I was told that those spacers should be enough to cure any rubbing that may occur.
Old Dec 29, 2006 | 02:41 PM
phantomroadking
6th Gear
I did use the spacers that came with the kit. I will check to see if anything is touching the floorboards or the frame. Thanks guys.
vtHDrider
2014-2024 Touring Models
13
Apr 29, 2018 07:15 PM
rjlman
Aug 23, 2011 10:09 AM
BJFLHT
Jul 6, 2011 12:34 PM
SG RIDER
May 28, 2011 08:40 PM
Chilhowee
Jun 2, 2008 07:56 AM
