Well almost.... Waiting on the tour pak bulbs, but other then that I have converted my eg to all LED.
I have the following:
Phase 7 driving lights.
( I did the phase 7 headlight but went back to stock due to daytime washout )
Front signals converted to led driving/signal ( white/yellow) with clear lenses.
Front fender tip converted to led board with smoked lens.
Tail light converted to custom dynamic LED tail light with smoked lens.
Rear signals converted to red LED running/brake/signals with smoked lenses.
Rear fender changed to smoked LED running/brake light.
And waiting for the LED bulbs for the corner tour pak lights.
Will post pictures after I finish the tour pak.
Btw if anyone is converting the signals on a Electra glide to running/brake lights, just be aware that the 1157 does not fit properly, because the stock is 1156. I had to bend the receptor a drop with a screw driver so the little nub on the bulb can twist in. But it works fine.
Looks good Biker90-
Which front signal are you using? Is it one of the Custom Dynamic new types?
I've been using the Kury's for 4 years on two bikes and like them; but the pix of your front signals got me thinkin'..........
