Gas Mileage on 2012 Ultra Limited
Old Apr 21, 2012 | 12:07 PM
DannyZ71's Avatar
DannyZ71
Only 250 miles? How many tanks have you gone thru?? Thats just one tank for me if I'm cruising down the highway and keep it steady with the cruise control. Every blip of the throttle eats more gas.
Old Apr 21, 2012 | 12:10 PM
DannyZ71's Avatar
DannyZ71
Mileage will also go up a tad when the winter blend of gas is no longer in the pumps. Also, unless you aee already doing so, find non-ethanol gas to run.
Old Apr 21, 2012 | 01:36 PM
mrfikser's Avatar
mrfikser
I have noticed that the mileage gets better with the warmer temps.....and its not the fuel (at least here) as this area has 10% ethanol all year long...
Old Apr 21, 2012 | 01:56 PM
kwo51's Avatar
kwo51
ez69 mine is a twin to yours .went from black to white, RK to Ultra. White is sure easier to keep clean. I have 2000 miles on it and have gotten 40 mph when driven easy. Gets 38 mpg riding like I stole it. Love this bike!
Old Apr 21, 2012 | 02:54 PM
mcw999's Avatar
mcw999
After 3000 miles, I get about 40-41. Freeway and country two lane mostly. You should average out 3-5 tanks of gas. Hard to fill exactly the same every time. Taking a measure over several tanks will reduce the varation in fill level.
Would like to get better mileage but like the power and driving at freeway speeds. Its all about tradeoffs.
Old Apr 21, 2012 | 07:38 PM
rushbass's Avatar
rushbass
Originally Posted by Geezr Glidr
I'm not doing that great on mine either. Last I checked at the pump it was only a little over 36. I heard that lower RPMs gets less mileage than higher RPMs. Any truth? I use 6th gear anytime I can stay over 2000.
I have found that staying out of 6th gear, and keeping my cruising RPM @ 3,000 (regardless of gear) is where I get the best gas mileage on mine. So, at 70 mph I am @ 3,100 RPM in 5th gear... I hardly ever use 6th anymore... 3000 RPM in 6th would be 80 mph.
Larry Green
Jul 8, 2012 09:40 PM
TCMAN
Sep 23, 2010 08:22 PM
h01waterman
Sep 17, 2010 10:17 PM
Black Bart
Jun 5, 2008 08:22 PM
SKJOLD
Apr 21, 2006 01:59 AM
