Engine Missing Until Warm
Old Apr 28, 2012 | 06:08 PM
KingCripps's Avatar
KingCripps
Default Engine Missing Until Warm
Question for you mechanics:
I had the heads ported and polished on a 2010 RK. I had the intake/exhast and a lot of other things apart (I guess if you are a mechanic, you know what it takes to remove the heads). The engine ran really good right after the heads were placed back on, but it has developed a miss until it gets warmed up. It is very pronounced, but it only lasts a couple of miles. No codes are thrown. Once warm, it really runs well.
I have the tank off again today and checking intake exhaust bolts to make sure they are tight. What else could be warming with the engine and tightening up? Could it be a head gasket? Should I ensure that the headbolts are still torqued to specs?
Thanks for any ideas.
Steve.
Old Apr 28, 2012 | 07:40 PM
RHillbilly's Avatar
RHillbilly
Could be a lifter
Old Apr 28, 2012 | 08:09 PM
speakerfritz's Avatar
speakerfritz
what maps and fuel management are you using?
Old Apr 28, 2012 | 09:05 PM
05LowRider's Avatar
05LowRider
Just tossing this out there. Could one of your head pipes have loosened up a bit and started leaking at the head. I've personally had this happen and a resultant miss. Might be worth checking. Good luck with the troubleshooting.
Old Apr 29, 2012 | 08:00 AM
KingCripps's Avatar
KingCripps
I've got the SE Pro Super Tuner installed. I have torqued the head pipe nuts a little more. None seemed overly loose.
I guess I'll put her back together and see what I get. Maybe I'll just have to break down and take her to the dealer for a $500 check up. They'll probably not find anything either.
ksarauer
May 15, 2019 09:04 AM
Tampa Fatboy
"The Florida Crew"
Aug 13, 2015 09:37 AM
yellowpearlfb
Engine Mechanical Topics
Mar 28, 2015 09:08 AM
Shaved Ice
Jan 29, 2012 06:03 PM
hockey8787
Sep 11, 2011 09:28 PM
