I don't get it.......
Old Apr 30, 2012 | 08:54 PM
jjpish's Avatar
jjpish
I have a 2011 EG Ultra with 4500 miles. The best mpg I have get since I bought it in September is 36 mpg. Of course coming home from OBX Bike Week yesterday 2 up with a loaded pack on the sissy bar I got 34 mpg. It was about 58 and windy so that plus the loaded pack maybe I should be happy with 34....
Old Apr 30, 2012 | 09:00 PM
Arizona's Avatar
Arizona
Originally Posted by brockstwrt
70 mph is the mpg line for me. Over 70 I get 35-38 under 70 I get 40-42. I've never seen 45 mpg in 15 years with 3 different Harley's.
Like you I only get 40 or so here in So Cal, but I've only seen those higher MPG's (well over 40 mpg) in other states, never here in CA. That's why I say the regional fuel blends must vary is all I can figure. I've noticed this more than once on my annual cross-country trip from San Diego to Illinois that I take every June. It shocks me too and it's frustrating to see as it's a dramatic difference (50 and 51 mpg's on consecutive tanks of gas!!).
Old Apr 30, 2012 | 09:14 PM
doc ock's Avatar
doc ock
Originally Posted by 2AMGuy
Keep those RPM's at 2800 and below and your MPG's will increase.
What he said. I get 40 mpg's on my out of town trips. Usually 35 in the city. It's not the MPH it's all about the RPM's. I keep my RPM's below 3000, put at about 70 MPH.
Old Apr 30, 2012 | 09:19 PM
RK Joy's Avatar
RK Joy
Originally Posted by Bill03E
You have a 5 speed trans , running 75-80 will suck fuel like there is no tomorrow, try riding at no more than 65 and see what it does.
True, sustained higher speed will drastically reduce your MPG, car, motorcycle, whatever. Once I was forced to follow a moving van through 5 stated at 55 MPH max. I was stunned to get 26 MPG on a lousy minivan on that trip!
Old Apr 30, 2012 | 09:20 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
got to love it,op is on a 02,not a 6 speed,not geared stupid tall,not with throttle numbing efi. as far as i know the 02 is geared much lower than even 04 much less a 07,efi has a built in throttle lagg it doesn't respond to every bump his carb has a accelerator pump that squirts in fuel with every jolt on the throttle hand.and his 02 isn't tuned epa lean.
norseman bagger's Avatar
norseman bagger
99 Carbureted with a full stage1, running 91 octane non ethanol gas, and I get about 34mpg every time.
Old Apr 30, 2012 | 09:29 PM
lh4x4's Avatar
lh4x4
My average on long tours with the 10 Ultra has consistently yielded 50 mpg.
I was pleasantly surprised when my 12 RG did the same.
That's loaded and keeping up with my sons.
Old May 1, 2012 | 08:59 AM
PktChg's Avatar
PktChg
I'm keeping a watch to stay under 3K and I am running a can of Sea-Foam through as well. The Sea-Foam, in the drive to the office, has made it run like a raped ape.......
Old May 1, 2012 | 09:13 AM
Pumba11's Avatar
Pumba11
I have a similar set up on my '99 Carb and typically get 40-42 even when riding 70+ and gunning it. The only exception was in the Rocky Mountains I was getting about 35 mpg.
Old May 1, 2012 | 09:14 AM
fabrik8r's Avatar
fabrik8r
As many have said, you have a relatively low geared 5 speed, my '06 EFI 5 speed does pretty well mileage wise at about 65 or below, anything above that is just sucks the gas. Your carb is not as efficient as EFI and your running a little rich, so I would say your fuel economy is right about where it should be. If you want more mileage, lean it out some more, keep the RPMs lower, or get a 6 speed gear box for ther slab.
