Is this normal
Old Apr 30, 2012 | 08:14 PM
jms1661's Avatar
jms1661
6th Gear
Question Is this normal
Had new burly bars installed on my SG 2012 dealer did all the work when i turn my radio on along with my driving lights my battery gage drops to 9 volts when i first turn everything on, when i start to take off the volts jump up to 13 when i come to stop they drop back to 9 volts is this normal or should i take back to dealer. i also leave the bike on a battery tender when i'm not going to ride it ......Juan
Old Apr 30, 2012 | 08:23 PM
Arizona's Avatar
Arizona
What did it read prior to the new bars being installed? Are these readings with the motor running? That sounds like quite a drop in volts. I'd guess maybe 12V and then back up to around 14V or so, but not down to 9V, that seems a bit extreme.
Old Apr 30, 2012 | 08:26 PM
gonzo3426's Avatar
gonzo3426
sounds like a short somewhere...or improper grounding...
Old Apr 30, 2012 | 08:27 PM
Chunker's Avatar
Chunker
Put a volt meter on your battery to check the voltage there compared to what the gage reads. Installed voltmeter is not vary accurate, at least not on mine.
Old Apr 30, 2012 | 08:32 PM
K Melancon's Avatar
K Melancon
Sounds like you need a battery.
Old Apr 30, 2012 | 08:41 PM
jms1661's Avatar
jms1661
6th Gear
this reading are with the bike running, i never notice this until i got it back from the dealer after my first ride with new handlebars. i'm going to check the battery tomorrow when i get back in town..will let you guys know the outcome..
Old Apr 30, 2012 | 10:19 PM
dbell66253's Avatar
dbell66253
Definetly not normal, if your guage is accurate, it cpuld be a few things, but something is definitely drawing too much, or not putting out enough, I would check the battery, regulator, and stator just to be safe.
Old May 1, 2012 | 04:47 AM
getty30188's Avatar
getty30188
loose connection at battery
Old May 6, 2012 | 01:25 AM
jms1661's Avatar
jms1661
6th Gear
got my bike back from dealer on saturday afternoon they told me they replace voltage regulator and the battery, service manager told me they took a voltage regulator from a new bike to replace mine, then he tells me that my ipod interface is not working properly he said they will need to take it off and send it out to get fix, i thought it was working just fine will read up on the ipod interface and what i can find..by the way my bike only had 500 miles on it before the voltage regulator went bad.....Juan
Grady10
Apr 19, 2017 03:49 AM
Jobobkr
Jan 25, 2017 11:43 AM
Mixter
Mar 30, 2014 03:23 PM
rome304
Aug 4, 2010 01:14 PM
JerryGarcia4295
Sep 9, 2009 01:03 PM
