Proper headlight alignment
Old Jan 4, 2007 | 12:48 AM
harlyd77's Avatar
harlyd77
Default Proper headlight alignment
Just lowered my SG 2" in the rear. Anyone know what the proper alignment is?
Old Jan 4, 2007 | 10:59 AM
billnourse's Avatar
billnourse
Default RE: Proper headlight alignment
If you will get a service manual, there are complete instructions for adjusting the headlight and passing lamps on all the dressers.
I can scan and print you the instructions, but it will be later this week before I can get it done. Let me know if that will work for you.
Regards,
Bill
Old Jan 4, 2007 | 01:44 PM
gunrunner's Avatar
gunrunner
Sit on bike on flat ground turn headlight on low measure from ground up to center of headlight bulb then measure 25 feet in front in straight line, then using a wall or piece of cardboard set center of beam to that hieght using the adjustment screw in edge of headlight bezel.
Old Jan 4, 2007 | 01:52 PM
swomack's Avatar
swomack
After you get it close go on a night ride move it up from there. I like my light down the road a bit.
bikerlaw
Dec 22, 2013 10:11 AM
craving94509
Mar 5, 2013 01:37 PM
scooter34
May 29, 2009 04:00 PM
rainman1977
Aug 8, 2007 11:33 PM
veniculum
Sep 8, 2006 12:18 AM
