09 and up model differences
I'm finally at a point where I'm able to start seriously looking at a touring bike, and I know the 09's and up have the newer frame with improved motor mounts and 2012 have the 103.
Any other differences, pro or con from 09-12 that I should take into consideration??
Will be looking mostly at Road King although I will be considering other models as well.
each year the model changes are given to Dealers in a .pdf form.
if you google:
2009 model year technical forum .pdf
then do 2010,2011,2012 you can follow the changes
mike
if you google:
mike
These load a little slow so be patient:
Here's the 2009 technical forum document: https://skydrive.live.com/#cid=3DBA5...650E1AF4%21639
2010: https://skydrive.live.com/?cid=3DBA5...95650E1AF4!643
2011: https://skydrive.live.com/#cid=3DBA5...650E1AF4%21476
2012: https://skydrive.live.com/#cid=3DBA5...650E1AF4%21480
