Very Important Question!
Old May 27, 2012 | 04:38 PM
trosel238's Avatar
trosel238
Default Very Important Question!
On my 2010 SG there is a plug-in on the left side of he inner fairing. The manual calls this a cigarette lighter plug-in and it says not to use it for plugging in accessories,... ie cell phone chargers, gps, etc.... I have ran my GPS off of this plug-in before, but now the plug has stopped working. How many of you run cell phone chargers or GPS devices off of that spot. Have you ever had any problems as a result. This is very important for me to know, since I am about to embark on a 2,000 mile road trip, and was planning on running my GPS from that plug. Thanks for your input in advance.
Old May 27, 2012 | 04:48 PM
Gliden's Avatar
Gliden
I don't know if Harley is just busting chops kinda saying to only use the cigarette lighter to light cigeretts but it has at least 3 amp fuse maybe 7.5 amp. I have to look. I hardwired my zumo but I can't think of a reason you can't use it . However......I know nothing about electrical engineering but I suspect any 12 volt source can run cell phone chargers or gps.
Old May 27, 2012 | 05:02 PM
Sam2010's Avatar
Sam2010
Things plugged in it can can hit gas tank when turned to left. I think that that is the reason not recomended.
Sparky73's Avatar
Sparky73
Agree with Gliden. Check your fuse to see if it's blown. Verify the fuse rating vs the current rating/requirement for your GPS. If it's been working fine, just pack a spare fuse or two for your trip.
If you're using the cig lighter for anything else (amp, hidden antenna, lighting smokes), the combined draw is probably what is blowing your fuse. Avoid any other use of your plug while the GPS is in use. Your best permanent solution would be a dedicated GPS power source.
Have a safe trip!
Old May 27, 2012 | 05:15 PM
trosel238's Avatar
trosel238
Thanks for the input. I'll check the fuse. Don't think my Garmin should be overloading it, but will look into that
Old May 27, 2012 | 05:27 PM
1st 96 ultra's Avatar
1st 96 ultra
yes it is not recomended for any other use because of posible binding of your steering , to big of piece in the plug
Marine Glider
Jan 25, 2016 11:33 AM
Betteroff
2014-2024 Touring Models
Jun 9, 2014 07:59 AM
broncobob
Mar 11, 2013 10:50 PM
gtrplyr
Jul 7, 2010 08:50 AM
pt4u2nv
Sep 8, 2008 09:51 PM
