No throttle response.
Old Jun 6, 2012 | 10:22 PM
Born2cure's Avatar
Born2cure
Default No throttle response.
I changed out the cams, lost oil pressure. Took it apart fixed problem with fuel pump. Now after putting all back I have good oil pressure no throttle response. When I try to rev it nothing idles nice but that's it. It's an 08 ultra! Any ideas would be appreciated. I'm thinking it's the O-ring on the pump but any other ideas would be checked.
Old Jun 6, 2012 | 10:27 PM
djaudette's Avatar
djaudette
Wow, I just wrote about mine going into limp mode. That is exactly what mine did. Will run about 20 MPH but no response on the throttle what so ever. It might be something different all together. What I am hearing is, it has to do with the TBW. Google TT418
Old Jun 6, 2012 | 10:41 PM
masterblaster's Avatar
masterblaster
Pull your TB plugs and spray with contact cleaner. apply some dialectric grease on the plug seals. Any other DTC's being thrown?
Old Jun 7, 2012 | 12:01 AM
cncmike's Avatar
cncmike
Mine would idle but die if I cracked the throttle. They said it had low fuel pressure and when they went to change the fuel filter found the fuel pump top was warped. Told me it is common in hot climates
Old Jun 7, 2012 | 07:17 AM
Born2cure's Avatar
Born2cure
Going to check the pins. Does anyone know if the o-ring on fuel pump can cause this. I heard if it goes you get no rev because the fly wheel cavity will fills with oil. I changed it when I did cams wondering if I could have messed it up.
Old Jun 7, 2012 | 09:37 PM
Born2cure's Avatar
Born2cure
Was the TB connection, didn't click all the way when I put it back together. Sounds good drives good now need to get it tuned.
Old Jun 7, 2012 | 10:55 PM
masterblaster
Do yourself a favor and hit it with contact cleaner and put dielectric grease on teh seals, I also spray wire dry on all connections especially the two TB cons, they have a SB out on this..
DAVENRINO
May 10, 2020 04:01 PM
splattttttt
19
Jun 7, 2018 11:07 AM
freashman06
Jun 26, 2017 08:46 PM
Talldog
May 20, 2016 11:33 AM
songsmith
Sep 26, 2007 09:24 AM
