engine races intermitently
Old Jun 21, 2012 | 02:43 PM
madjack4's Avatar
madjack4
Stage I
Default engine races intermitently
Hi ive got a problem with my 2008 electraglide screaming eagle 110 every now and then when started from cold it tickes over at 2500 rpm even when warmed up if i turn off ignition then restart it ticks over ok any idea ?
Old Jun 21, 2012 | 04:06 PM
SDVmnt's Avatar
SDVmnt
I know there was an issue with the IAC (Idle Air Control Valve) on the '07's. I'm not certain if that carried into the '08's though. I've got a buddy with the same issue on his '07. Spraying carb cleaner into the hole a few times to clean it up has helped so far.
Old Jun 21, 2012 | 04:37 PM
angelrod's Avatar
angelrod
idle air control Valve , most likely , you can unplug that thing and start the bike , if it do same thing . that is your problem . that how i tested mine . its not that expensive , and easy to replace
FXD_noob
Nov 18, 2015 10:07 AM
studad52
Jul 19, 2013 12:43 AM
Bushy
Sep 22, 2010 08:59 PM
ggibson
Nov 12, 2008 07:12 PM
valkal
Exhaust System Topics
Aug 18, 2008 09:34 AM
