Bagger Apes Moving
Old Jul 4, 2012 | 03:54 PM
Kaz800's Avatar
Kaz800
Default Bagger Apes Moving
Had Cyclesmith 13" Bagger Apes installed on my FLHX this spring. They started to move after hitting bumps. Went back to dealership the mechanic tightened then a little more then the suggested PSI. Started to move again yesterday. He said they had pretty knurling on them. That it was the nature of apes.
Thoughts...suggestions.
Thanks for the help
Old Jul 4, 2012 | 04:05 PM
drtracy07's Avatar
drtracy07
rubber bushings move alot when you get the bars up in the air.. i was told to put neopreme bushings in because they are tighter.. hope it helps
ZenGlide's Avatar
ZenGlide
This may not be the correct answer, but in my opinion any handlebars that are not rubber mounted/isolated should not move at all. I would be concerned about any unintended movement of my main steering control.
Old Jul 4, 2012 | 04:38 PM
08HD's Avatar
08HD
This is what you need...
http://www.amazon.com/Polyurethane-Heavy-Duty-Handlebar-Dampener-1973-2012/dp/B005ND2458 http://www.amazon.com/Polyurethane-Heavy-Duty-Handlebar-Dampener-1973-2012/dp/B005ND2458
Old Jul 4, 2012 | 04:59 PM
DvlDg29's Avatar
DvlDg29
Don't have apes on the SG yet but had them on my FatBoy and was told to use the polyurethane bushing. They are much stiffer, the original rubber ones are just too week for non-traditional heights. My apes never once moved.
Old Jul 4, 2012 | 05:17 PM
steelhead's Avatar
steelhead
The mechanic is wrong. Use poly bushings and then loctite and torque the **** out of it and they will not move.
Old Jul 4, 2012 | 05:24 PM
SteelCityRider's Avatar
SteelCityRider
I switched to Poly Bushings and have not had a problem. I had to chenge the clamp to a 1 piece clamp also. Torqued to spec.
Old Jul 4, 2012 | 07:07 PM
mstng5point0's Avatar
mstng5point0
I had this problem wtih 12" apes on my night train. I did poly bushings when i put them on, the problem was they kept rotating in the clamps. I tightened them as much as i could without breaking the bolts and they still moved. I read online to take some emery cloth and slide it in between the bars and clamps. I did this and they havent moved since.
Old Jul 4, 2012 | 07:29 PM
senna's Avatar
senna
If the bars are rotating in the clamp, look into one of these,
Fifth item down on the page
http://www.baggernation.com/products-bars.htmI
Old Jul 4, 2012 | 07:45 PM
bdouglas215's Avatar
bdouglas215
5th Gear
I had issues with my 18" apes rotating on my '06 Road King. After the 2nd time of taking everything apart to re-adjust and tighten I did some searching online. Wound up wrapping emory cloth on the handlebars, rough side out, and glueing emory cloth on the insides of the risers and clamp, rough side out. Then torqued it all down. That was probably over 1000 miles ago and they've not budged since.
heavymetalthunder
Jul 14, 2017 02:38 PM
Fourdogs
Jul 9, 2016 09:37 AM
shaker
Sep 10, 2013 05:35 AM
BigGelvis
Jun 13, 2013 04:54 AM
levihd
Aug 19, 2012 07:34 PM
