Antenna help
Old 07-07-2012, 02:12 PM
Pyrotag's Avatar
Pyrotag
Pyrotag is offline
Default Antenna help
I have a 2012 street glide and installed a boom hidden antenna. For the most part it works fine but I'm detecting some static. I didn't remove the original antenna wire and was thinking to reconnecting it and puttig a pigtail connector in the back of the radio and connecting both. My question is since the boom antenna Is powered will this cause any issues and second any ideas where I can find a pigtail to fit the Harley radio. Thanks for ur help
Old 07-07-2012, 02:30 PM
bradsULtd's Avatar
bradsULtd
bradsULtd is offline
Can't connect both at the same time...it will create a miss-match between the antenna and the radio...its one or the other...
Old 07-07-2012, 03:25 PM
WLS's Avatar
WLS
WLS is offline
+1 You'll burn out your radio!
Old 07-07-2012, 03:38 PM
Pyrotag's Avatar
Pyrotag
Pyrotag is offline
Thanks for the info
Old 07-07-2012, 03:43 PM
Armstronges's Avatar
Armstronges
Armstronges is offline
What color is your scoot?
Old 07-07-2012, 05:47 PM
gmc's Avatar
gmc
gmc is offline
I have a powered hidden antenna from Pep Boys and a y splitter with just the antenna wire hooked up to it and everything is fine, works better than just the hidden antenna.
http://www.ebay.com/itm/CAR-RADIO-AN...item415bf54c52
Old 07-07-2012, 06:05 PM
Verbal's Avatar
Verbal
Verbal is offline
How will that burn out the radio? You're just adding another signal path to the radio.
I'm not questioning anyone's expertise here, just looking for an explanation since I don't have any expertise on the subject.
The reason I ask is when I took my fairing off, I found an antenna wire laying across the inside that was hooked up to a small box the size of a cigarette pack. I did notice that I was losing my FM radio signal after a short 30 mile trip west (all previous trips werew east of the radio station that I listen to). I do have the shortys on my bike and was thinking of trying both inputs for maximum signal strength.
Old 07-07-2012, 06:16 PM
acchd's Avatar
acchd
acchd is offline
I run a y-splitter with a in fairing hidden antenna & a Tour Pak & Fender antenna works great!
Old 07-07-2012, 06:22 PM
Armstronges
Kinda pointless to use both antennas isn't it? Kinda defeats the purpose of the "hidden" antenna. I'm a firm believer that the color of the fairing effects how well the hidden antenna works.
Old 07-07-2012, 06:41 PM
acchd's Avatar
acchd
acchd is offline
Normally hidden antenna inside fairing via y-splitter is done when you detach tour pak you have backup antenna without need relocate tour pak antenna.
Quick Reply: Antenna help
