Can You Adjust Angle of Front Left Footboard
Can You Adjust Angle of Front Left Footboard? The front bracket mount has an adjustable slot that looks like you can; but I cannot find a way to loosen the rear bracket so I can tilt the front of the floorboard up a bit to match right side. Can anyone help? I've looked in service manual and tried loosening a bunch of bolts, no luck.
My god, what a mess - especially when it is 108 degrees outside at 6PM. You cannot adjust the tilt; i.e., have front higher than than the back. You could if the side stand was not there, and you can adjust the tilt on the right side of the bike. Because of the way the sidestand mounts you can only raise or lower the foot board a couple of holes, but not tilt it.
Ecker27
General Topics/Tech Tips
07-02-2019 03:46 PM
