Hi all got a 2012 ultra and just ordered some xieds for it. I've seen them installed in different spots on the bike and was wondering where they go on this one? Is it right behind the right plastic cover? I know there's a ground wire i got to hook up. Probably be to the negative post on the battery. Thanks for your help!
From: Payson, AZ within 400 miles of the best the west has to offer for riders
The XIEDs add about 8% in the closed loop portion of fueling. Overall 5% seems reasonable. I have 02 IEDs and see about a 4% drop in mileage. The bike pulls stronger i
in the closed loop range so you can go into a higher gear and save some gas. There is an increase in fuel in open loop as well, due to the adaptive fueling tables in the ECU.
Go to www.nightrider.com for more info.
