Good luck, mine was on with dbl sided tape, but felt like it'd been welded on. Wasn't concerned with salvaging it so I finally pried it off. You might want to try a heat gun and a lot of patience!
The flame thing will fit on over the insert--no need to remove it.
OR....
If you like the slightly closer tolerance without it, pick up a used fottball at a swap meet, or see if your dealer has one in the take-off pile. They practically GIVE 'em away.
Now that I have mine removed I'd like to replace the 'ring' with something else. Right now its just a chrome football cover. I seen a screaming eagle ring that looked pretty cool but I'm open for ideas that I'm not going to need to drop a'C' note.
I went with the Screamin' Eagle ring. It is subtle and added just a touch of color.....
I have a SE trim ring that came with my Stage I kit I never used. PM me if you want it.
