Getting Rinehart endcaps off???
Old 08-04-2012, 04:06 PM
Alykhan's Avatar
Alykhan
Alykhan is offline
Default Getting Rinehart endcaps off???
Anyone have any tips for getting the endcaps off of my pipes? I got the screws out but the caps are being a pain in the ***!
Old 08-04-2012, 04:30 PM
2004Sierra's Avatar
2004Sierra
2004Sierra is offline
Yeah, they are a pain in the azz to get off. They use red RTV around the cap and it glues it in place.
I ran a piece of 2" wide painter's tape twice around the cap to protect it, and then used a rubber strap wrench to twist the cap. Once you get it broke loose you still have to work at it a bit to get it off.
Old 08-04-2012, 08:27 PM
maryvillept's Avatar
maryvillept
maryvillept is offline
Did either of you guys actually is the red permatex on the other end of the muffler? I personally didn't not as I didn't see a reason to
Old 08-04-2012, 09:02 PM
Mike's Avatar
Mike
Mike is offline
I use anti-seize when I install the end caps, it helps when it comes time to pull them off. The strap wrench is a good tool. Spray some PB blaster in the joint and let it work. Then try the strap wrench, and/or hit the end cap on opposite sides with a rubber mallet. Then more PB blaster, let it work for a bit and try some more. Eventually they'll come loose for you.
Old 08-04-2012, 11:39 PM
2004Sierra's Avatar
2004Sierra
I didn't use any red rtv at the inlet of the baffle.
It seemed to fit tight enough without it. I thought it would only make it harder to get out next time.
I did put a very thin layer around the end cap. I thought it might keep exhaust soot from from leaking around the cap.
Old 08-04-2012, 11:44 PM
RaceFace's Avatar
RaceFace
RaceFace is offline
Mine came off pretty easy but the strap wrench is what I would have grabbed if they fought me. Good luck!!
Old 08-05-2012, 07:15 AM
TickTock's Avatar
TickTock
TickTock is offline
Go to harbor freight and buy a slide hammer. If you can get it hooked to the inside edge then a couple of taps should get it moving.
Old 08-05-2012, 07:23 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,229 Likes on 1,628 Posts
I did the same w/tape, but beat the snot out of the caps (top/bottom/Left/Right) with a rubber mallet to break loose. Don't worry about damaging the cap - they're pretty stout & if the tape starts coming apart...add more layers.
Old 08-05-2012, 08:37 AM
elPrez's Avatar
elPrez
elPrez is offline
If they're still on the bike, running it to warm them up can also help.
Bandit111
Exhaust System Topics
11-09-2016 12:11 PM
harley7316
03-30-2015 10:24 AM
rbferg
10-19-2014 03:11 PM
RKLeo
09-28-2008 02:04 PM
prb107
Oil Archive (no new posts)
07-25-2006 11:01 AM
Quick Reply: Getting Rinehart endcaps off???
