No Throttle Response
Old Sep 7, 2012 | 04:52 PM
DC2009EGUC's Avatar
DC2009EGUC
Default No Throttle Response
I was happily riding to work this morning on nice and dry 75F weather on interstate 5, then all of a sudden, the check engine light came on…I started losing speed…I twisted the throttle and no response at all.
I quickly pulled over to the side, turned off the engine from the “run” switch, then restarted the engine, check engine light stayed lit, and again no throttle response, and I noticed the idle RPMs at about 1500.
I shut the engine a second time from the “run” switch, waited about two to three minutes, then restarted the engine, and the throttle response came back, check engine light was off, and my normal idle RPM is now back to normal of about 950 to 1000 RPM. Continued to ride to work for 20 miles no issues.
I just got back from riding to Sturgis this year, about 3000+ miles with no issues. I am completely puzzled? Has anyone experienced this?
Bike is 2009 Ultra with PC V, V&H monster ovals, and Arlen Ness Big Sucker Stage I.
Help?
DC
Old Sep 7, 2012 | 05:09 PM
johngp7's Avatar
johngp7
Check the connections on the TBW at the trottle behind the A/C....mine was loose, disconnected it , cleaned the connections and put dielectric grease on it....still works
Old Sep 7, 2012 | 06:05 PM
wtb3886's Avatar
wtb3886
You have just experienced LIMP mode, the connectors to your air filter need to be changed to the larger pin size & reset the DTC code.
berniemc
Jun 16, 2015 10:06 PM
jbyun
Apr 4, 2010 05:44 PM
Handycam
Aug 16, 2009 09:22 PM
Tom Ricci
Jun 21, 2008 04:14 PM
FFeric
Oct 4, 2006 08:58 PM
