clock set
Old Sep 15, 2012 | 06:55 PM
biil9's Avatar
biil9
Default clock set
i have tried every combination i can think of and now i have to ask you guys this dumb question. how do you change the time on a 2003 electra guide. thank you. i wish i was joking
Old Sep 15, 2012 | 07:01 PM
KaponeWKYA's Avatar
KaponeWKYA
I don't know if 03 is the same as my 08 (I'm thinking it should be), just turn the radio off, on the lower right side you should see a soft key (next to the #6 preset button) that says 'SET', press 6, then hours +/-, minutes +/- soft keys should appear until you set it to the time you choose. Hope this helps...
Old Sep 15, 2012 | 07:04 PM
flyingace's Avatar
flyingace
The radio changed in 06 or 07.
Old Sep 15, 2012 | 07:23 PM
KaponeWKYA's Avatar
KaponeWKYA
Whoops! Hopefully someone in the know will chime in shortly. You don't have an owner's manual? Is it available online?
Old Sep 15, 2012 | 07:27 PM
flyingace's Avatar
flyingace
Damn, Ive searched the net for 30 mins, no joy. No wonder your asking here.
Im sure someone with the older radio will chime in.
Old Sep 15, 2012 | 07:34 PM
Midgitfire's Avatar
Midgitfire
According to a post on another forum, turn on bike, turn off radio, press the "4" button. Hope that helps.
Old Sep 15, 2012 | 07:49 PM
KaponeWKYA's Avatar
KaponeWKYA
Yeah, I've been checking for about 30 minutes with no luck either...hopefully, someone else helps out...good luck!
Old Sep 15, 2012 | 08:11 PM
glide2meetu's Avatar
glide2meetu
If you create a login on the HD website the basic manuals, ie operations, owners, safety, are there for your particular model.. Thats where I can read mine anyway...good luck.
Old Sep 15, 2012 | 08:20 PM
Snowfly's Avatar
Snowfly
My 05 ultra is done this way. The time of day is set with the ignition/headlamp key switch to ignition or access but with the receiver off. Press the hours (HRS) button on the receiver front panel to increment the hours in the display. Pressing and holding HRS will cause the hours to continue to increment until the button is released.
Press he minutes (MIN) button on the receiver front panel to increment the minutes in the display. Pressing and holding MIN will cause the minutes to continue to increment until the button is released.
Hope this helps
Old Sep 15, 2012 | 08:23 PM
rleggs's Avatar
rleggs
Exactly,,,it will say set beside the button on the display, hold the button in push hrs. and min up and down.
