Brake bleeder
Old Sep 17, 2012 | 09:00 PM
MJR's Avatar
MJR
Default Brake bleeder
What size wrench do I need for the bleeder on the front brakes? 3/8 and 10 MM are both too large.
Old Sep 17, 2012 | 09:14 PM
ericl's Avatar
ericl
I installed my chromed caliper yesterday, 3/8"
Old Sep 17, 2012 | 09:22 PM
MJR's Avatar
MJR
Thanks Eric, it seemed like the nut might round off if I increased the pressure while trying to open the bleeder valve. the 3/8 seems a little loose.
Old Sep 17, 2012 | 09:27 PM
ericl's Avatar
ericl
I used a boxed end.
Old Sep 17, 2012 | 10:37 PM
Pelonz's Avatar
Pelonz
I used a 3/8 12pt socket
Old Sep 18, 2012 | 06:04 AM
jjnoble's Avatar
jjnoble
Real men use their fingers.
Since you are going to loosen them, think about replacing them with speed bleeder valves.
Old Sep 18, 2012 | 08:25 AM
TUCCI's Avatar
TUCCI
Unless your keeping the bike forever many people do their brakes maybe once and speed bleeders are overkill not to mention they stick up to high for my liking......their almost 1/2-3/4" higher than stock if I remember correctly....
Old Sep 18, 2012 | 09:06 AM
CurtisO's Avatar
CurtisO
I know with the speed bleeders I am more likely to replace the brake fluid instead of putting it off. I never noticed the height difference.
Old Sep 18, 2012 | 09:14 AM
RaceFace's Avatar
RaceFace
As advised above......Speedbleeders bro! You cant go wrong.
Old Sep 18, 2012 | 09:15 AM
jjnoble's Avatar
jjnoble
Mine are actually smaller than the stock ones.
They make it easy to bleed and or replace the brake fluid by yourself, and as long as you do not let the cylinder run dry there is no way to get air into the lines. Well worth installing even if you do not plan on keeping the bike forever. And since they are so easy to install, if they fit, you can easily transfer them to your new bike, so keep the stock bleeders just in case.
