Power Vision Tuner
Old Sep 20, 2012 | 02:42 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by casique
I'm confused, do you need an additional module or part? Or is the autotune capability just a free software upgrade? Thanks.
This is a free upgrade and allows you to use Auto Tune Basic with your factory O2 sensors, with AT Basic you do not need to purchase any additional components. If you choose to use Auto Tune Pro you would use the optional Wideband Auto Tune kit.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Sep 20, 2012 | 02:43 PM
Boston62's Avatar
Boston62
Dynojet is releasing a new firmware upgrade in Oct, which has Autotune built in using you O2 sensors, or with the wide O2 sensor in the Autotune Pro Add on.
You won't have to do it on the PC, you can do everything right from the device.
I am running the Beta of it, glad I went with the Power Vision than the TTS Master Tune.
Old Sep 20, 2012 | 02:44 PM
WetSider's Avatar
WetSider
Having read the info on DJ's web site, this is an update to the PV software, and you can use Autotune-Basic to do auto tuning with your stock narrow-band O2 sensors (no addt'l equipment/$ required), or do Autotune-Pro which requires 18mm wide-band O2 sensors in your header pipes and DJ's wide band control module (which you have to purchase).
Old Sep 20, 2012 | 02:45 PM
casique's Avatar
casique
Can you point me to the autotune instructions? Thanks.
Old Sep 20, 2012 | 02:49 PM
The Q's Avatar
The Q
http://blogs.dynojet.com/index.php/2...now-a-reality/
Old Sep 20, 2012 | 03:37 PM
fevest's Avatar
fevest
So with the pv if you have the wide band o2. What do you do after the pv flashs the ecm and you take off the pv? I didn't think the ecm could use the wide band o2 sensors.
Old Sep 20, 2012 | 04:05 PM
morleyz's Avatar
morleyz
You have to keep the PV connected during data logging/auto tuning. once you have a "final" tune downloaded into the ECM, you can disconnect the PV. The ECM cannot use the wide band o2s directly.
Old Sep 24, 2012 | 08:17 PM
ethiel's Avatar
ethiel
Please forgive my ignorance.
So, I install the power vision on the handlebars and press auto tune and then go for a long ride (30 mins to an hour?). Then come back and upload it into the ECM?
Old Sep 24, 2012 | 08:40 PM
Keithhu's Avatar
Keithhu
Its a bit more complex than that, start here:
https://www.hdforums.com/forum/10349794-post3112.html
Old Sep 24, 2012 | 08:54 PM
ethiel's Avatar
ethiel
Ok, so I follow those instruction but my question is, Do I have to go for a ride with the PV connected or I just do the auto tune with the info already stored in the ECM?
