LED Lights
Old Sep 21, 2012 | 08:27 AM
Brusier1028's Avatar
Brusier1028
Default LED Lights
I have an 07 Street Glide.
I want to replace the turn signals lights and rear brake light, turn signals, and licence plate light with LEDs. Whats out there, where to buy? I want to do a dark smoked out look on the ambers up front. Smoked out red on rear and the break light. Thanks for the help.
Old Sep 21, 2012 | 08:31 AM
frog13's Avatar
frog13
I like Custom Dynamics for the lighting and Biketronics for the load equalizer. I like Biketronics because it is plug and play with no battery lead. Custom Dynamics has a great reputation, I run red on the rear with smoked lenses and Dynamic Ringsz on the front with smoked lenses, white when running, amber when turn signals are on. Search Garemlin on the forum, he has some good pics of this setup.
Old Sep 21, 2012 | 08:55 AM
Garemlin's Avatar
Garemlin
Custom Dynamics all the way. LED clusters front and rear and grab a Biketronics Smart Equalizer from a vendor such as Eastern Performance. Lifetime warranty on everything I listed. CD also sells smoke lenses way cheaper than HD. They are like $2 each.
And here is my thread that frog mentioned if you are interested.
Dynamic Ringz LED front signals by Custom Dynamics installed
Old Sep 21, 2012 | 09:13 AM
Esuomm1's Avatar
Esuomm1
some talk here
https://www.hdforums.com/forum/touri...-dynamics.html
Old Sep 21, 2012 | 12:32 PM
Brusier1028
That was a great write up on your CD.
Old Sep 21, 2012 | 12:35 PM
Brusier1028
Same place for rear LEDs or some other brand?
Old Sep 21, 2012 | 01:09 PM
Brusier1028
So if i read it all right on an 07 I will use a 1157 up front and 1156 out back?
Old Sep 21, 2012 | 01:49 PM
Garemlin's Avatar
Garemlin
That is correct. Front is dual filament. Rear is single filament. While you are on the correct upgrade path might as well throw in a Biketronics Tailbones run/turn/brake module.
And yes Custom Dynamics for your rear signals too.
Old Sep 21, 2012 | 02:00 PM
Brusier1028
Can someone comment on the Bike Tronics equalizer. Do I need the 801 or 802. I think it's the 801 but I can find out which one.
Old Sep 21, 2012 | 03:00 PM
Garemlin's Avatar
Garemlin
You will use a BT801.
