Voltage Fluctuation While Accelerating
Old Sep 23, 2012 | 04:58 PM
papasnipe's Avatar
papasnipe
Default Voltage Fluctuation While Accelerating
I am loosing my mind, I was riding to work the other day and I noticed that everytime I got on the throttle of my 2004 Electra Glide Classic the headlight would dim as would all my gage lights. Then on the way home from work I got the battery and the check engine light on and off for the 8 mile trip home. Now if I am at an idle I have no issues but as soon as I twist my lights dim until I drop back down below 2500 RPM. Any ideas, I really dont want to take it to the dealership if it is something I can fix. I was thinking I may need a new Voltage Regulator but I dont want to drop $150-$250 for it to be something else
Aaron
Old Sep 23, 2012 | 05:04 PM
Gliden's Avatar
Gliden
Do ya have a buddy you could swap regulators with?
Old Sep 23, 2012 | 05:31 PM
mkguitar's Avatar
mkguitar
I wonder if you might have a wire shorting when you accelerate.
with the bike on, motor off- start moving things- start with the battery cable.
it is more than possible for the insulation to wear through on the + cable.
you should also use a real voltmeter at the battery while you do this.
everything up front voltmeter lights etc. runs through the same wire and the same ign. switch ( which can burn out if high watt bulbs are used)
mike
Old Sep 24, 2012 | 10:59 AM
Mark98012's Avatar
Mark98012
I would FIRST check the battery connections, they are famous for coming loose. Also check the alternator plug. If they all check out I would put a meter on the battery and read it while on the bike (to see if it's charging or not). It would have to be one hell of a short to pull everything down, and if it were that bad of a short your bike would more than likely be cutting out. Good luck.
Old Sep 24, 2012 | 11:06 AM
fwb35's Avatar
fwb35
Mine was dropping below 12 volts at idle this weekend, pulled the seat and found the + cable loose
Old Sep 24, 2012 | 12:40 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
I'm with the "check your connections" crowd.
Also, how old is your battery?
A week battery can make a bike do weird things.
Old Sep 27, 2012 | 08:20 PM
Gliden's Avatar
Gliden
Aaron
So what was it?
Old Oct 17, 2012 | 06:56 PM
armydgp's Avatar
armydgp
Sorry to dig up old threads but mine is doing the same thing, i'm about to check the connections now
Danny
Old Oct 17, 2012 | 08:42 PM
armydgp's Avatar
armydgp
Fixed it, cleaned the battery terminals and realigned the spacer, works great now
Danny
wharfcreek
Jun 18, 2019 11:11 PM
e3tim
Electrical/Lighting/Alarm
Sep 17, 2016 08:45 PM
Darrin Palmer
Mar 16, 2014 08:31 PM
Constantine77
Mar 27, 2013 10:37 AM
straydog13
Ironhead
May 4, 2008 02:37 PM
