Have a miss while running after replacement of battery
Old Sep 17, 2016 | 03:12 PM
e3tim's Avatar
e3tim
Stage II
Default Have a miss while running after replacement of battery
I replaced the battery on my 2002 heritage classic. After replacement the bike ran fine for about 5 minutes. Then it started spitting and sputtering and idles rough . While idling when it's starts to idle low the lights dim . I feel.like there is an electrical issue . Possibly a bad ground . I have checked all the fuses they all look good. The battery is good and I have checked plug wires and battery cables. Need some help with other things to look for .
Old Sep 17, 2016 | 08:41 PM
Ed Ramberger's Avatar
Ed Ramberger
You need to check and verify the bike is properly charging. Check the charging output at the battery. If it's low, check the stator output. If that's good, you're most likely looking at a regulator. However, you should always start with basics like connection integrity, etc.
Old Sep 17, 2016 | 08:45 PM
TSheff's Avatar
TSheff
Need to do A Voltage Regulator and Stator check, and double check the battery, Even though it is new it could be bad or have been - damaged in shipment.
tnguyen7607@email.vccs.edu
Jan 25, 2017 12:21 PM
sharpshooter08
Jun 12, 2013 04:51 PM
Ten-Ring
Sep 17, 2010 10:22 AM
51Moe
Aug 16, 2010 08:07 PM
d59s67
Jun 23, 2007 10:51 AM
