Rear brakes on UC
he should be telling you, no?
check caliper condition, pistons moving freely, seals good, no leaks
look for wear and tear, grooved/warped/damaged rotor.
smooth bearing and wheel operation.
check some fasteners
Since I do not know what year/model/miles your bike* has...maybe wheel bearing service
probably wants to check the brake fluid...does it need flushed and replaced ?
if a late model has the brake switch recall been performed ?
Mike
* some riders assume that there year/model info will show up if entered in profile or a pic- that is not always the case. easiest to enter that info in the first post
Mike
