Changed battery, bike now dead. Factory alarm related...
Old 11-01-2012, 09:44 PM
Twinrider's Avatar
Twinrider
Twinrider is offline
Default Help: changed battery, bike now dead. Security system related
I've got the factory security system on my bike. I spaced out and changed the battery without first disabling the security system by putting into service mode. When I disconnected the battery, the alarm went off for about a minute, then stopped. I proceeded to install the new battery, but now the bike is completely dead. No power to ignition, speedometer or anything else not connected directly to the battery. I'm guessing the anti-theft mode is disabling the ECU. Can't even manually enter the disarm code to reset the alarm.
Any advice on how to fix this problem would be greatly appreciated.
Old 11-01-2012, 11:32 PM
vzts4q's Avatar
vzts4q
vzts4q is offline
check your maxi fuse!
Pulling the maxi fuse while the key is on is also the easiest why to prevent the alarm from going off. But then again the international models may be differant.
Old 11-02-2012, 12:04 AM
Twinrider's Avatar
Twinrider
The problem isn't shutting the alarm off now, but how to get the bike started as the electrical system appears to be completely shut down. I think the alarm might have immobilized the ECM when I disconnected the battery without first putting the alarm into service mode. Or maybe something else needs to be checked that I'm overlooking.
Old 11-02-2012, 07:37 AM
vzts4q's Avatar
vzts4q
vzts4q is offline
Like I said check the maxi fuse. It could be blown this is the most likely cause of your problem and the easiest to check.
The reference to pulling it was for future reference to keep the alarm from going off.
Old 11-02-2012, 09:01 AM
Twinrider's Avatar
Twinrider
OK, I am an idiot.... I went out this AM to see if I could figure out the problem before taking it to the dealer. Checked all the fuses and wiring connections. As I examined the positive extension cable with all the accessory wires attached to it, it dawned on me that I wasn't seeing the bike's main positive cable. Doh! It turned out that it had gotten shoved down when I put in the new battery and I had never connected it. Hooked it up and all was good. Thanks for the help and sorry for wasting your time!
Old 11-03-2012, 08:46 PM
Tactical111's Avatar
Tactical111
Tactical111 is offline
Great that it was that simple! Thanks for letting us know the solution as these things can drive a body mad. Had a similar deal once where my trickle charger wasn't charging. Turns out I had left the positive lead off the battery terminal. Duh!
Bud Marrott
General Topics/Tech Tips
03-26-2017 06:22 AM
herbacide
02-18-2017 11:21 AM
Potato_Potato
05-23-2014 10:38 PM
craving94509
07-04-2013 08:46 AM
rolodog
05-23-2010 05:16 PM
Quick Reply: Changed battery, bike now dead. Factory alarm related...
