gear drive cams???????
Old 11-08-2012, 08:13 AM
SkipCarey's Avatar
SkipCarey
SkipCarey is offline
Default gear drive cams???????
Title says it all...thoughts /reccomendations for my 11sg 103
Power duals,V&H fuel pak ,K&N aircharger,CFRs(I know im gonna need a new tuner)
Old 11-08-2012, 09:28 AM
Glockmeister's Avatar
Glockmeister
Glockmeister is offline
I'd go chain
Old 11-08-2012, 09:46 AM
Hammy's Avatar
Hammy
Hammy is offline
supposedly the chain drive shoe issues have been fixed. I put gear drive cams in my 07 as the shoe wore through and almost fell apart at 18,000 miles.. I ended up putting in gear drive cams at that time.
I have chain drive cams in my xbones (it's an 09) I don't ride that as much so I've yet to find out if they did improve or not.
Old 11-08-2012, 09:51 AM
Hammy's Avatar
Hammy
Hammy is offline
I have the woods 7HG cams in my 106 I make over 100ft lbs from 2500-5700rpms with peak of 124ft lbs at 3500 around 108hp from 4700-5700rpms peak hp 108 at 5200
choose a torque cam, there is valve noise (its a woods cam)..
Old 11-09-2012, 08:27 AM
electra glide's Avatar
electra glide
electra glide is offline
Hammy, the 07 was supposed to be the new hydraulic nylon tensioner wasn't it? That was the first year for the upgrade I thought. I read in American Iron about the belt driven cam that woods developed, and it is supposed to be superior to either the chain or the gear. i think it's probably pricey, and I personally thought it was kinda weird looking, but performance wise it's supposed to be awesome.
Old 11-09-2012, 09:24 AM
mr396's Avatar
mr396
mr396 is offline
To go with Gear cams, you will need to check your crankshaft runout. If it is over .002-.003 then you will have problems going with gear cams.
Old 11-09-2012, 10:51 AM
fxdxrider's Avatar
fxdxrider
fxdxrider is offline
No need on your year of bike. It was pre- 2006 Dynas and pre 2007 Softies and Baggers that had the tensioner issues.
Old 11-09-2012, 10:57 AM
Gigawitz's Avatar
Gigawitz
Gigawitz is offline
Gear driven cams are superior, less rotating mass, better performance, and less points of failure.. Yes, the chain system is greatly improved on newer TC's but it's still a chain system, go for the gears if you can!!
Old 11-09-2012, 11:04 AM
Energy-Dude's Avatar
Energy-Dude
Energy-Dude is offline
Ive got a buddy with 110k on his 09 Streetglide with the stock cam chain tensioners. All with stock cams which are easier on them compared to larger performance cams, but no issues yet.
Old 11-09-2012, 11:07 AM
05FLHTC's Avatar
05FLHTC
05FLHTC is offline
Thumbs down Not true
I'm calling the statement above BS and something more likely to be a sales pitch.
Gears require repeatable & tight tolerances...something not likely capable of being supplied with the OEM crank.
If you absolutely are convinced that you have to run gears with yr motor then spend the cash to upgrade the bottom end 1st.
Quick Reply: gear drive cams???????
