A silly question
Old Nov 22, 2012 | 06:44 AM
FL-kruzen's Avatar
FL-kruzen
Default A silly question
I have my front end apart to replace the fork tubes and sliders. Between the triple trees there is two, (one on each side) big rubber groments that the fork tubes slide through. At first thought they appear to be there to prevent total bottom outs, but that can't be because they slide on the fork tube between the upper and lower triple tree. So, what are they for?
Old Nov 22, 2012 | 06:51 AM
hawg50's Avatar
hawg50
Default fork stops
these are called fork stops.they keep the front end from turning too far in either direction.
Old Nov 22, 2012 | 07:55 AM
grbrown's Avatar
grbrown
I am in much the same situation at present! Hawg has it, so remember to put them back on!
Old Nov 22, 2012 | 09:55 AM
mrfuji's Avatar
mrfuji
Default a silly question
hi .if i remenber right those 2 rubbers cylinders. have 2 fonctions.1 your tube do not hit the tank.2you have play between triple tree so you can go up-down to balance the front of your bike..if bike pull left. bring left down right up.my 2011 flhtc do not have those .may be new frame thing.they d ont even have the locking plate for the top nut on tree. they says use locktight. very stupid.mrfuji
Old Nov 22, 2012 | 11:30 AM
FL-kruzen's Avatar
FL-kruzen
Hey! Thanks. Now that makes since! Thanks
simms346
Jan 15, 2016 09:15 AM
tattoofever
May 21, 2013 07:18 AM
ramu3527
Aug 4, 2012 07:47 AM
jtbredneck351
Ironhead
May 7, 2010 07:58 PM
Scout
Mar 3, 2006 08:09 AM
