Conversion cams
Old Dec 10, 2012 | 06:00 AM
andyp's Avatar
andyp
Default Conversion cams
I am in the process of changing my cams in my 04 FLHTC to Andrews Conversion cams and need the instructions on 07 and up HDs for cams.My service manual covers most of it but dont want to miss anything.
Old Dec 10, 2012 | 06:08 AM
grbrown's Avatar
grbrown
Andrews has a wide range of instruction sheets on their website. Do any of them answer your queries?
Old Dec 10, 2012 | 07:11 AM
andyp's Avatar
andyp
The instructions Andrews gives are for cams only.
Old Dec 10, 2012 | 07:33 AM
vickers1's Avatar
vickers1
Here's a great video showing the procedure.
Old Dec 10, 2012 | 11:18 AM
andyp's Avatar
andyp
Thanks
Old Dec 10, 2012 | 12:35 PM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
I understand very little of the mechanics of this, but do you not have different cam chain tensioners?
Old Dec 10, 2012 | 12:40 PM
fwb35's Avatar
fwb35
He does but said he is putting in conversion cams, that means he is putting a different cam plate in like the one in the video.
Old Dec 10, 2012 | 12:55 PM
jmorganroadglide
See, I told I didn't know much
Old Dec 10, 2012 | 01:12 PM
grbrown's Avatar
grbrown
Wink
The conversion AFAIK is from the original spring-loaded chain tensioners, to oil pressure or hydraulic tensioners. The spring type used on TC88s wear badly and can cause serious damage if they fail, the hydraulic variety were introduced on the TC96 and can be retro-fitted to TC88s. It's a common upgrade, as the later spec has a higher pressure oil pump, as a bonus.
Hope that helps!
nickybandy
Mar 1, 2021 12:36 PM
jack6hd
Sep 18, 2015 03:55 AM
jlb0038
Jul 6, 2011 08:38 AM
darkdyna06
Feb 24, 2008 11:35 PM
HDF Tech
Engine Mechanical Topics
Oct 22, 2005 11:46 AM
