Intermittent start issues need help
Old Dec 11, 2012 | 03:45 PM
Houston_t's Avatar
Houston_t
Default Intermittent start issues need help
heres the deal sometimes when I turn the ignition on the fuel pump won't prime and when ever this happens I also get nothing from the starter. Thought it was a issue with the factory alarm so I replaced the tssm with a tsm and didn't have a issue again until today. Had the faring off to replace the radio and noticed when I move the wire harness bundle the fuel pump goes in and out, thought I was on to something so I started unplugging connectors one at a time to try and trace down the harness bundle with issue. I unplugged one of the black connectors with the thicker wires apparently one of the main power feeds because the front lights went out and after I plugged it back in lights came back on but now no matter how much I play with the harness I can't get the pump to kick back on. Not sure what may of happened by disconnecting and reconnecting that one plug but I caused a problem, fuses are good so now I'm wondering is there anyway to test the fuel pump like maybe through the relay and would the fuel pump not working cause the starter to not engage ?
Scott E Dawg
May 27, 2019 11:17 AM
zschaeff205
Jul 14, 2016 10:41 AM
stal94gt
27
Mar 19, 2016 05:10 PM
ramu3527
Aug 13, 2012 08:41 PM
Tropicalwarrior
Jun 18, 2010 06:31 PM
