Replace Handlebars TriGlide
Old Jan 16, 2013 | 01:26 PM
gapatriot's Avatar
gapatriot
Default Replace Handlebars TriGlide
Besides what is mounted on the handlebars, how much of the fairing must be removed. The parts guy at my dealer said if I knew anything about wrenching, I should be able to do it. I want to replace the handlebars that brings them 2 inches closer to me. Thanks in advance for advice.
Old Jan 16, 2013 | 01:52 PM
craigffb's Avatar
craigffb
The outer fairing needs to be removed and the the inter fairing will need to be pulled up off the trees so you can lean it forward to get at the clamp. Just search for bar changes on any of the bat wing bikes it's all pretty much the same. There is a ton of info on here.
Old Jan 16, 2013 | 06:16 PM
glide2005's Avatar
glide2005
Remove the front fairing, then pull the radio, and the switch housing. I've never removed anymore than that, and I've installed several sets. Installing the bars are not hard, just time consumming. Take your time, and pay attenion where everything came off so you can put all the parts back where they belong.
Old Jan 16, 2013 | 06:39 PM
gapatriot's Avatar
gapatriot
Thanks for that info. That doesn't sound to bad. I'm sure the dealer would get about $200 for that job.
Old Jan 16, 2013 | 07:08 PM
glide2005's Avatar
glide2005
The dealers get closer to a grand for bar change. If all they charged was 200 bux, I'd lettum do it.
Old Jan 16, 2013 | 07:24 PM
gapatriot's Avatar
gapatriot
I'll give them a call tomorrow. You probably are right. I think it's time we start nogotiating the cost of the job.
ironman2011's Avatar
ironman2011
Honestly, a service manual, and a couple searches on here to verify a couple steps was all it took for me. You can do it just fine, and if you have any problems, there are a ton of people here to help.
Old Jan 16, 2013 | 07:29 PM
gapatriot's Avatar
gapatriot
ironman2011, you are probably right. I remember when I had a 2003 Goldwing and I had to replace the air filter, that was a job. I got everything put back with no problems. So I probably with dust off the service manual and go get the handlebars. Thanks for the encouragment.
Old Jan 16, 2013 | 08:49 PM
TNCarters's Avatar
TNCarters
Been looking at doing this on my Ultra. Dealer time depends on internal or external wiring and whether clutch and brake lines have to be replaced. There are several video and slide shows referenced on here of the swap. I'm going to try and do mine myself as dealer wanted 7 hours labor and replacing all lines which I know from this forum is not needed for KW 2+2's. I think they just threw out a worst case number because they were busy at the time I asked.
Been thinking its about time to start the winter project as its in the 30's here now and city just salted all the roads for this last sleet storm.
PeteF
2014-2024 Touring Models
15
Dec 28, 2016 07:57 AM
Harley Hound57
Apr 3, 2016 09:45 PM
nyokie
EVO
Sep 29, 2015 06:18 AM
Jswerve
Dec 29, 2012 04:20 PM
Boom
22
Sep 6, 2010 07:52 AM
