Handlebars adjust, maybe replacement
Old Sep 27, 2015 | 11:32 AM
nyokie's Avatar
nyokie
Default Handlebars adjust, maybe replacement
On a 95 eelctra glide what do i have to pull to get to the bar clamp? Just outer fairing or radio as well? Anyway to do it without opening the fairing through through ignition switch etc? Nothing in the HD service manual about removing bars
Old Sep 27, 2015 | 12:58 PM
WP50's Avatar
WP50
I have done it by removing the top of Ign switch and cover and the radio.
It was job but got it done, a couple of cut allen wrenchs needle nose vice grips. It's been to long to remember the particulars of it. I think the manual said to remove inner fairing. I didn't want to go that far doing what I needed.
Now this was on a 97 EG I need to mention.
Time to break out the chop saw again (just kidding)
WP
Old Sep 27, 2015 | 01:03 PM
nyokie's Avatar
nyokie
Yeah was looking at parts breakdown book on 95 model and it almost looks like my ignition switch cover is part of the inner fairing and not a separate piece. haha right this is looking like a bit of work
Old Sep 27, 2015 | 02:27 PM
WP50's Avatar
WP50
I went and looked just now
A bit of work you say
Pulling the inner fairing on mine was a lot work (repaint)
Hope somebody knows a good shortcut for ya.
Did see an ultra with the bars being change (90 sumptin) and they had the inner fairing supported with straps to a rafter so as not to have to remove the whole fairing. That's what I was told when I asked.
WP
Old Sep 27, 2015 | 03:16 PM
mkguitar's Avatar
mkguitar
big diff from the 95 fairing to the 96+ ( on which this is a 15 minute job).
on my 95, I was able to remove ignition and lower dash panel and get in there with a wrench...pretty sure I was able to leave the radio in place.
a cut off piece of 1/4" allen and a 1/4" wrench
Mike
Old Sep 27, 2015 | 09:18 PM
langwilliams's Avatar
langwilliams
my 06 was easy to do this on with the 96+ batwing. I had a heck of a time realigning the ignition/neck lock though.
Old Sep 28, 2015 | 05:54 AM
nyokie's Avatar
nyokie
Mike
So on the 95 the ignition switch cover is separate from inner fairing?
Old Sep 28, 2015 | 10:55 AM
IBDAGRIZ's Avatar
IBDAGRIZ
Your 95 is like my 94. Remove outer fairing and pull the radio out and you'll have access to the handlebar clamp to swap bars, etc. Pull the radio chassis it slides into out too. Four allen heads behind the rubber edge of chassis for radio.
Griz
Old Sep 28, 2015 | 04:41 PM
nyokie's Avatar
nyokie
sound like enough hassle to go ahead and do bagger apes while i have it apart...... new project!
Old Sep 29, 2015 | 06:18 AM
DeputyLoud's Avatar
DeputyLoud
Griz
Exactly how it is on my '91. Last weekend I put a stereo in and had access to the clamp again. I moved my apes as far up and forward as possible. Amazing what another 1.5" made to my hand position. I Like!
Harley Hound57
Apr 3, 2016 09:45 PM
Buttz
Apr 12, 2013 11:37 AM
bbs15
Jun 12, 2012 07:27 PM
bikerick
Dec 5, 2009 03:35 PM
lmb1485
Nov 18, 2008 05:58 PM
