I'm changing cams in my bike which is a 05 Ultra with 24,000 miles. Its in a local indy shop getting the crank run measured to see if I can run a gear drive set up. My question is does any know the part numbers to use the Hyd style tensioner to upgrade if i cant use the gear drive. Im either going to use the S&S 509 or Andrews 21 or 26 cams. Thanks for the help
