Gear Driven Cams
Old May 26, 2012 | 12:56 PM
Gooch's Avatar
Gooch
Default Gear Driven Cams
Does anyone know how they achieve the proper timing on the cams since the rotation is changed when changing from the chain drive to the gears. You can get just the gears without the cams, but since the rotation is changed from both the same (with the chain) to opposite each other ( with the gears) how is the timing not affected? Any ideas to help my troulbled mind would be greatly appreciated.
Old May 26, 2012 | 01:43 PM
oct1949's Avatar
oct1949
here's one of the best write ups I've ever seen on doing cams.
Just read through it and It will show and tell U how to set up the timing marks.
https://www.hdforums.com/forum/touri...-write-up.html
Old May 26, 2012 | 01:57 PM
Stiggy's Avatar
Stiggy
The cams you'll choose (even if purchased separately,) are for gear drive applications and they're 'keyed' to time correctly.
( You can't use gears on chain drive cams.)
Old May 26, 2012 | 02:01 PM
Gooch's Avatar
Gooch
Thanks Oct1949, but that post is for using a chain drive, which turns both cams in the same direction, using gears causes them to turn in opposite directions. This was my concern, how can these companies like S&S or Andrews sell just the gear sets. In my mind the front cam will turn "backwards" with a gear drive set up changing when the valves open and close.
Old May 26, 2012 | 02:02 PM
Gooch's Avatar
Gooch
Thanks Stiggy, cleared that up!
Old May 26, 2012 | 02:08 PM
oct1949's Avatar
oct1949
OOOps,,,that showed my about gear cams....
Oh well I did have good intentions to help Ya..
fishnpo
Jan 23, 2019 06:48 AM
Tcobfxdxt
Sep 1, 2014 08:52 AM
dlwilson72
Sep 24, 2013 12:29 AM
Marsh
Nov 5, 2008 09:43 AM
Marsh
Nov 4, 2008 09:57 PM
