Ignition switch issue
Old Feb 19, 2013 | 08:48 PM
nivensid's Avatar
nivensid
Originally Posted by fat daddy
There's a guy on this forum that sells a tool for $15-$20 and it works great I've used it several times and I'm HMO it's well worth the money
Makes the job so easy a caveman could do it.
Old Feb 19, 2013 | 09:07 PM
the warden's Avatar
the warden
I am about to do my front sliders (chrome), and presumably need to remove some part of my fairing, so I will need to remove my ignition. Who is the member that sells this TOOL?
Old Feb 19, 2013 | 09:20 PM
Retrop's Avatar
Retrop
Originally Posted by flhxmc
I recently upgraded my front forks so I had to take the ignition selector off. When I reinstalled it I notice that when I turned the key to lock you can still turn the ignition on. I am not sure if I have an alignment issue from taking it off? No I do not have that tool.
Thanks
Mike
Here is a video that will help you make the tool and remove the switch. Best video for switch removal I have seen. It is about 5 years old but nothing has changed.
Old Feb 20, 2013 | 07:06 AM
fat daddy's Avatar
fat daddy
Go to www.marcparnes.com he sells a variety of tools pretty good stuff too.
Old Feb 20, 2013 | 05:00 PM
leon anthony's Avatar
leon anthony
if you look at the shaft of the switch you will see all the lugs tha stick out from the shaft
If you notice that they are of a differant size on each side of the shaft. Now take a long stright slot screw driver and line the slots in your switch with all the same size slots on the same side and the switch will drop right in
Old Feb 20, 2013 | 05:53 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
The craftsman flat screwdriver in your tool box will work just like the $20 tool.
Old Feb 20, 2013 | 08:58 PM
BackRoader's Avatar
BackRoader
Multiple cams or whatever you want to call em down there.The holes must all be aligned the same.
Old Feb 20, 2013 | 09:02 PM
BackRoader's Avatar
BackRoader
Most people reach in there with a screwdriver, don't go deep enough, and fail to turn all of them, screwing up the alignment.
Old Feb 21, 2013 | 06:14 PM
leon anthony
read my post again it will work take you five min.
Old Feb 22, 2013 | 06:46 AM
fat daddy's Avatar
fat daddy
Yeah I've used the screw driver method however I think for $20. I like using the tool I can turn the front wheel and start my bike without worrying about aligning any cams up. I think 20 bucks is a small price for the tool that will make it much easier . If I didn't want to spend the money than I would at least make a tool to do the job.
