Electrical question.
Old Feb 22, 2013 | 02:36 PM
RK Fan's Avatar
RK Fan
Default Electrical question.
Is the harness HD sells for the aux. plug under the seat the best way to use that circuit or do you guys cut the plug off and solder whatever directly?
Old Feb 22, 2013 | 03:50 PM
littled62's Avatar
littled62
plug it in, there is not much wire left on the plug under the seat to cut off and not much room for soldering
Old Feb 22, 2013 | 05:06 PM
RK Fan's Avatar
RK Fan
Thanks for the tip.... I called my local HD dealer and they have a harness in stock.... $17.95.... I'll pick one up...
Old Feb 22, 2013 | 07:11 PM
littled62's Avatar
littled62
just watch out, one side is controled by the acc switch on the dash the other is hot all the time
Old Feb 22, 2013 | 07:44 PM
RPS1981's Avatar
RPS1981
I didn't want to cut my factory wiring, so I bought the harness you're talking about (it actually gives you two plugs if I recall correctly?) and spliced into that...
The four wires are (1) hot when key is on (2) hot when key is on and ACC switch is on (3) hot when key is on and brake is on and (4) ground.
Old Feb 22, 2013 | 09:17 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
u can use crimp on duetch connecters,they plug right into the holes,about 12 cents apiece.
lbkr22
Aug 19, 2021 03:29 PM
Mechengineer03
Jun 16, 2012 09:18 AM
cruzmisl
Oct 11, 2010 05:32 PM
bucs012
May 28, 2008 09:27 AM
renorush
Apr 11, 2008 09:42 PM
