Is this "Clunk" normal?
Old Mar 2, 2013 | 06:07 PM
FL-kruzen's Avatar
FL-kruzen
Default Is this "Clunk" normal?
If i hit a large bump that or a drop off, the front forks go "clunk". Is that the fork sliders extending to the stops that makes this sound?
Thanks for any info.
Old Mar 2, 2013 | 06:23 PM
Scuba10jdl's Avatar
Scuba10jdl
It's normal. There is a piece in there that moves during compression, and then the suspension creates a vacuum when it comes off of full bump at high speeds, which in turn makes a clunk as the piece slides back in place quickly.
Old Mar 2, 2013 | 06:25 PM
BlackSpecial's Avatar
BlackSpecial
What year and model? There was a service bulletin a few years ago about front end "clunk" as I recall.
Old Mar 2, 2013 | 06:45 PM
FL-kruzen's Avatar
FL-kruzen
it's an 2001 FLHTC. With air pressure in the front shocks and if you say, drop from a bump, the pressure would push your lowers to the stop, and that's what I think is happening
Old Mar 2, 2013 | 06:48 PM
ULTRABAGGIN's Avatar
ULTRABAGGIN
My 01 Wide glide does the same thing. Had it checked out a few years ago and nothing was wrong.
Old Mar 2, 2013 | 06:50 PM
Scuba10jdl's Avatar
Scuba10jdl
You'll get some clunking type of noise at both full extension and compression. This is the fork mechanism for preventing it from getting damaged. There is a rebound spring for extension and oil lock, as I described before, for compression.
Old Mar 2, 2013 | 06:51 PM
Juan L's Avatar
Juan L
Moderator
Normal?
Old Mar 2, 2013 | 06:52 PM
troop8520's Avatar
troop8520
Not saying its not the forks, but is it possible it was the jiffy stand ??
sci
EVO
Jul 27, 2016 08:12 PM
FreedomRider
EVO
Oct 30, 2013 05:26 AM
BFFBPhil
Jul 25, 2011 04:51 PM
JCleary
Jul 15, 2011 04:57 PM
ky_ace
Jul 14, 2009 11:49 PM
