Want some advise on what to look for... looking at an '01 SE Road Glide
Thanks in advance! I am looking very seriously at a 2001 Screaming Eagle Road Glide tomorrow morning. 40k, really clean. Has Reinharts, K&N filter, and a PC III. I know about the M/M EFI, and this one seems like it has been well taken care of. The owner prepped it for Sturgis last season with new fork seals, brakes, tires, & cam chain tensioners. I'm thinking that is the EFI isn't spot on, at the price i can get it for, I'll throw a Zipper's kit on it. I've heard that I need to look for a hairline crack on the swingarm, but am not sure what side or where. Anything else I need to consider? Thanks!!!
read my thread and it will show you most things that could be wrong.
https://www.hdforums.com/forum/touri...g-a-flhpi.html
i'm usually very picky about what i purchase and let my gaurd down on this bike because i wanted another project to get my knowledge back up on harley's
next bike will be a low mile one. while 40k isn't bad. it can open a can of worms if the maintenance wasn't kept up.
main things i would check for concern:
rust on frame. defiantely on the tail section and upper front
check for oil seepage around the jugs and rocker box's
wheel bearing end play (try and wiggle the wheel side to side from the top)
wiring, pull the seat and check for any cut wires or redneck engineering
dry rot tires
check oil in trans and engine
fuel gauge probably won't work, they suck anyways
and if you're real serious, bring a jack and check the swing arm bushing for play. also the drive belt. that's a big chore to replace either
hope that helps
mike
dry rot tires
hope that helps
mike
Same question asked here on a virtually identical bike. Check it out.
https://www.hdforums.com/forum/screa...oad-glide.html
Mine is the absolute the best Harley I've ever owned. The 99 to 02 motors are the only Twin Cams with a hot forged crank and the Timken Lefty bearing so they are without question the strongest bottom ends of the Twin Cam era,
Because of that I went with gear drive cams (Andrews 26,) and eliminated trhe tensioner issue forever.
The area 1/2" in front of the axle on both the top and bottom of the swingarm, ( either side,) is the weak spot on the swingarm. Mine did crack and I had it repaired with a TIG weld and a 1/2" x 1/2" patch over the repair so it's also now bulletproof.
My M&M injection is quirky on cold starts but is perfect when warm so I'm not complaining. The motor revs willingly and puts out about the same HP/TQ as a Stage I 110" CVO today.
Maybe this year I'll check out a stabilizer but apparently haven't felt the need to yet.
I just passed 125,000 on my '00 and it's my main transportation pretty much year round to work. I love my bike.
http://www.jamesrussellpublishing.bi...buyharley.html[/quote]
Disregard most of what this guy has to say, he's just trying to sell his books. The rear swingarm & the cam tensioners are the main concerns & both can be easily upgraded.
Check both sides regularly and fix if and when necessary. Or upgrade to an '02 and later swingarm as Gary did.
And I have too, although to get the stiffer stronger swingarm, rather than any failure of my original one. As a little fun I also added a Deuce rear wheel!
