led lights
Old Mar 16, 2013 | 04:43 PM
mtnroadking's Avatar
mtnroadking
Default led lights
Put LED lights on front and rear turn signals. Put the pulse flasher on as well. But took it back off as it would not work right. So right now I have the inline reducer plugged into the rear lights. I have noticed that the turn signal indicator lights on panel stay lit up all the time. I need some help here in what to do and what is right.Thanks folks.
Old Mar 16, 2013 | 04:54 PM
bklynbob's Avatar
bklynbob
Buddy had the same problem. He rode the bike for about a week and and the problem disappeared..................go figure!
Old Mar 16, 2013 | 06:43 PM
1st 96 ultra's Avatar
1st 96 ultra
loose connection or bad ground , is your reducer powered , if so check the bat connections
Old Mar 17, 2013 | 03:19 PM
pastime's Avatar
pastime
I had a similar problem after installing Kuryakin LED turn signals, turned out the load equalizer overheated and fried. Dealer replaced the equalizer at no charge and relocated it to get more air flow to stay cooler. I haven't had a problem since. I do know I can't leave the turn signals on at long stop lights tho....no sense in tempting fate. Hope this helps.
Rebel55
Apr 20, 2015 10:06 PM
prosport76
Electrical/Lighting/Alarm
Feb 10, 2013 07:40 PM
totprod
Jun 16, 2010 03:58 PM
Lorenzo_82
Apr 14, 2009 01:06 PM
tobster
14
May 4, 2008 11:01 AM
