Old Mar 28, 2013 | 09:59 PM
ken1960's Avatar
ken1960
Default 107
i have 107 motor an put a 58mm throttle body on i have stock injectors in her now , if change them to 53.2injectors will that be a noticble change in power
Old Mar 28, 2013 | 10:35 PM
WI Bob's Avatar
WI Bob
Tell us more about your build.
What cam, how much compression, exhaust, intake, current HP/TQ?
What year?
You likely would not notice anything but a harder to tune low end.
Old Mar 29, 2013 | 02:25 AM
VibratingPotato's Avatar
VibratingPotato
If you have a strong build with ported heads n stuff and much over 100 HP, you may benefit using 5.3 injectors.
But a 58mm TB on a 107 is too big in my book.
Old Mar 29, 2013 | 04:03 AM
stupid_rope's Avatar
stupid_rope
agreed. 58 is way too big
Old Mar 29, 2013 | 06:16 AM
SlimsSG's Avatar
SlimsSG
I can tell you it was highly recommended for my build. Of course I have ported heads (Dewey Heads), 10.5:1 compression, and a 55mm TB. You should talk to a performance shop also.
Old Mar 29, 2013 | 06:48 AM
lkr0's Avatar
lkr0
have to agree 58 is way to big for a 107 - at times bigger does not = more power -- also with motor builds you get to the point of deminishing returns
Old Mar 29, 2013 | 09:20 PM
ken1960's Avatar
ken1960
it has 102hp an 110 tq, got 10to1 comp 575 mackey cam revolution perf. heads 58mm throttle body, v&h powerdualls monster ovalls, rev. perf. tuner
Old Mar 29, 2013 | 09:30 PM
soft 02's Avatar
soft 02
You would gain more on the bottom end with a smaller TB. You prolly need the larger injectors too. Dont know about your tuner but you need to tell it when you install injectors. Did you put this combo togather?
Old Mar 29, 2013 | 09:44 PM
ken1960's Avatar
ken1960
yea , dealer ordered wrong pistons ,i wanted 10.5 to1, i thought bigger injector make more power with that setup
Old Mar 29, 2013 | 11:50 PM
CigarCritic's Avatar
CigarCritic
In general, larger throttle body, more HP. Either go with an Autotuner or find another human tuner, your numbers are low for your build. Larger injectors are not going to solve your issue with low numbers.
txphatboy
Engine Mechanical Topics
51
Apr 5, 2015 12:46 PM
MCCHP
Exhaust System Topics
94
May 31, 2014 06:34 AM
97badfatboy
Jan 6, 2011 12:49 PM
FLHXXHLF
45
Apr 9, 2009 12:14 PM
gpp
Dec 17, 2007 04:42 PM
