abs question
Old Apr 25, 2013 | 09:41 PM
gator rider's Avatar
gator rider
6th Gear
Default abs question
hi folks, quick question, I have a new to me 2008 ultra classic with abs, on my speedo the abs light will come on and off intermitently. Im not sure if its supposed to be on all the time or just when there is a problem.One person told me it should be on at first but should go off when bike reaches 5 mph. does this sound right? also any thoughts on what I should start with in troubleshooting problem? I checked front caliper resevoir for brake fluid level and it was ok but was unable to check back brake because i need someone to hold bike upright to check level and i was alone. thanx for any help
Old Apr 25, 2013 | 09:45 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I wanted ABS but didn't get it. I found that out when I read the manual and how the light is supposed to flash when you first start it up, to show it's working. Other than that, I don't know how it works.
Old Apr 25, 2013 | 09:55 PM
saxfiend's Avatar
saxfiend
According to the owner's manual (I also have an 08 Ultra), the ABS light should go off once your speed reaches at least 3 mph, and that's how it works on mine. So if yours is staying on or flashing, something's not right.
A quick search on this site came up with a thread that discussed a similar problem, and in that case, it looks like there was a broken or disconnected wire: https://www.hdforums.com/forum/showthread.php?p=9894723
JL
Old Apr 25, 2013 | 09:56 PM
K Melancon's Avatar
K Melancon
In an automobile the ABS will test itself once when the vehicle reaches 5 mph after start up. Probably the cycles test it self also at 5 mph. I know the light stays on until I take off, but I never looked at what speed it does this. I know if you are in your vehicle after start up and you put it in gear, if you lightly ride your brakes when you hit 5 mph you will feel the pedal pulse against your foot. This is the ABS pressuring up the lines quickly to test itself.
I will try this with the bike next time if I can remember to holdmy brakes after start up and at 5 mph.
Old Apr 25, 2013 | 10:20 PM
EricD10563's Avatar
EricD10563
JL
Light should go off and stay off once you reach 5mph, I'm part of that thread and I had a wire that was being pulled up by the triple tree. If the ABS comes on after that it has detected a fault.
Old Apr 26, 2013 | 03:43 AM
longrides's Avatar
longrides
Your ABS light should flash when first started until you start moving then it should turn off. If it's flashing while riding you should have it checked.
Old Apr 26, 2013 | 08:49 AM
shore's Avatar
shore
where is this wire?
Old Apr 26, 2013 | 10:32 AM
EricD10563's Avatar
EricD10563
Originally Posted by shore
where is this wire?
Left side of the steering neck, it was the wire going into a wire connector it's a two wire connector for the front wheel ABS, it was factory ziptied to something causing tension when the handlebars turned. I cut the ziptie and reparied the wire and never had a problem again.
This was on my 09 Road King
Old Apr 26, 2013 | 08:44 PM
gator rider
6th Gear
Thumbs up
thanx everyone for the help, gonna trouble shoot with your suggestions.
Old Apr 27, 2013 | 07:15 PM
shore's Avatar
shore
I checked that harness and the wires appear fine. Nothing obvious at least.
