07 RK Custom headlight not centered
I adjusted my handlebars this weekend. I reinstalled the headlight and trim ring. There is no longer an even space all around the headlight (between the headlight outer edge and trim ring), yet there was even spacing before I took it apart.
To me it's a bit odd as the headlight is firmly mounted with screws through rubber mounting points, and the trim ring is firmly mounted as well (no adjustment points). Looking at it there's really no adjusting points to center the headlight within the trim ring. I didn't mess with the headlight adjusting screws, only the 7 (8?) mounting screws that hold the headlight to the nacelle. The rubber mounts don't appear damaged.
Any suggestions?
Any suggestions?
DarkManC
01-23-2009 08:16 AM
