headlight rattle
Old May 11, 2009 | 07:41 PM
wooosaa's Avatar
wooosaa
Default headlight rattle
so the headlight rattles a bit on my 04 deuce...is there a gasket or o ring or something that I lost or it didnt have......seems excessively loose and I have the lower trim ring screw tight........
Old May 12, 2009 | 06:01 AM
wooosaa's Avatar
wooosaa
Bueller....Bueller....Bueller???????
Old May 12, 2009 | 06:37 AM
SoftailC's Avatar
SoftailC
The one on my custom used to do the same thing. If yours is the same as mine, it is because it is rubber mounted. I found a fix on this forum awhile back and now it is rock solid.
Old May 12, 2009 | 07:02 AM
SoftailC's Avatar
SoftailC
This was the thread I used to fix my shaking headlight problem https://www.hdforums.com/forum/softa...the-place.html.
Old May 12, 2009 | 09:33 AM
wooosaa's Avatar
wooosaa
Default clear it up
i dont have a big problem with the bucket rattling its actually the light fixture inside the bucket....It came with the frosted glass and I replaced it with the crystal clear lense and now it seems like the whole light assembly shakes in the bucket......does it need one of the new trim rings????? kind of puzzled
Old May 12, 2009 | 10:29 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
If it is the socket the bulb plugs into I would wrap some electrical tape (a fair amount) around the socket and put it back in. If it is the trim ring, do the same thing, wrap the outer edge of the light with a bund of electrical tape. Put back together and shake it too see if it has fixed the problem. My headlight started rattling after the last bulb change and it turned out I lost a small piece of plastic that would hold the trim ring firm in place. I wrapped it with electrical tape and is fine now. I could have gone to the dealer and gotten the piece I lsot, but this was quicker and easier.
jimdaddywells
Jun 6, 2017 03:17 PM
red deuce
Jan 2, 2017 04:01 PM
cbaywolf
Aug 18, 2015 08:17 PM
rjammo
May 10, 2013 04:27 AM
DarkManC
Jan 23, 2009 08:16 AM
