If I am going in there....
Old 05-16-2013, 09:13 AM
mr396's Avatar
mr396
mr396 is offline
Default If I am going in there....
I am hearing the sounds of my primary inner race bearing going out again. Had it happen a couple years ago and recognize the sound. At that time it was covered under warranty so I had the HD dealer replace it. This time it is not and I like to wrench on cars, bikes, etc. Same bearing going out twice in 5 yrs, hmmm.. does HD have an issue here.
Anyway, if I am going into the primary to replace the bearing I would like to get some feedback.
- how big of a job is this? yes I do have a service manual. looking for some personal experience and advice here. Is is better to just take it to the HD shop, did I say that out loud?
- any special tools I may need for this?
- Is there a post of how to do this anywhere on this forum?
- what bearing should I put in there. Don't think I want to go back with HD bearing.
- I presume I should replace the primary chain tensioner with Hayden or something similar.
- what else should I check, replace, or upgrade while I have the primary torn down. I have about 35k miles on an 2008 Ultra Classic with a 103 ci engine. I am letting you guys spend my money so expect some great suggestions
Old 05-16-2013, 09:29 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
the only thing I will suggest is do not use air impact tools on the clutch nut ( left hand thread) or the compensating sprocket bolt.
Mike
Old 05-16-2013, 11:15 AM
mr396's Avatar
mr396
mr396 is offline
Thanks for the feedback
any other suggestions guys
Old 05-16-2013, 11:26 AM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
You will need the main shaft race tool.
http://www.georges-garage.com/trans_06_up.htm
danzio
07-21-2016 10:50 AM
hAkron
05-31-2016 07:07 PM
DMetcalf
09-11-2015 03:46 PM
Hog Heaven
08-24-2012 10:31 AM
cncmike
06-20-2012 10:46 AM
Quick Reply: If I am going in there....
